Negative total energy value using compressible model
roberto.bernetti
Post by roberto.bernetti »
I tried to run a compressible calculation on version 7.04 downloaded from the web site installed on a ubuntu WSL2.
I cant upload the mesh, too data. This is the error that I get
   1: 0x7fa418641cfd <typecl_+0x3a78>                 (libsaturne-7.0.so)
   2: 0x7fa4184dfd30 <condli_ini_+0x40f>              (libsaturne-7.0.so)
   3: 0x7fa4184ab218 <caltri_+0x748>                  (libsaturne-7.0.so)
   4: 0x7fa419371b97 <main+0x717>                     (libcs_solver-7.0.so)
   5: 0x7fa4182070b3 <__libc_start_main+0xf3>         (libc.so.6)
   6: 0x56420519308e <_start+0x2e>                    (cs_solver)
setup.xml
(10.41 KiB) Downloaded 636 times
Saluti
Roberto
roberto.bernetti
I overcome the previous errror checking the "hydrostatic equilibrium at wall" box.
But now I got the following error:
Error in thermodynamics computations for compressible flows
Negative values of the internal energy were encountered in 1 cells.
   1: 0x7fed4f7d9dc5 <cs_cf_check_internal_energy+0x2d5> (libsaturne-7.0.so)
   2: 0x7fed4f7d054e <cfener_+0x1863>                 (libsaturne-7.0.so)
   3: 0x7fed4f323154 <scalai_+0x6e5>                  (libsaturne-7.0.so)
   4: 0x7fed4f32dbd9 <tridim_+0x44a1>                 (libsaturne-7.0.so)
   5: 0x7fed4f19c6ff <caltri_+0x1c2f>                 (libsaturne-7.0.so)
   6: 0x7fed50061b97 <main+0x717>                     (libcs_solver-7.0.so)
   7: 0x7fed4eef70b3 <__libc_start_main+0xf3>         (libc.so.6)
   8: 0x55cfc237008e <_start+0x2e>                    (cs_solver)
Saluti
Roberto
Thanks for the feedback on the previous thread.
But please do not hijack an existing thread, at least when it is old. This makes searching through the history more difficult for us, as if we go back a few posts, we will see different explanations.
I made the same remark to another user on this same thread. So if you read this thread, you must have seen it. this remark applies to everyone. So please create a new thread instead.
Also, try to post a longer part of the error message. I do not even know whether you have a SIGSEGV, floating-point exception,
or other type of error, and this information is essential for debugging...
[edit : I have split this thread from the previous one]
roberto.bernetti
Thanks.
I'll create a new thread.
Saluti
Roberto
