Problem with Python version for version >=3.10
mstorti
Post by mstorti »
Hi all,
I wonder if someone has stumbled on this problem before. CS stopped to work after upgrade to Fedora 35. It compiles and installs OK, but when trying to run a case it results in an error
   File "/home/scratch/mstorti/TO-BACKUP/DATA-CD/saturne-vof/bin/code_saturne", line 67, in <module>
     from cs_script import master_script
It seems that the problem is that in many Python scripts within CS the major.minor version of Python is obtained as sys.version[:3] which fails unless both numbers have one digit. I'm using CS 6.1 but I checked with the current version and it seems that the problem is still there.
I solved it replacing in the sources sys.version[:3] with the following string:
python_version = "%d.%d" % (sys.version_info.major,sys.version_info.minor)
Find attached a patch in case it helps.
pyvers.patch.zip
(1.39 KiB) Downloaded 987 times
Re: Problem with Python version for version >=3.10
Thanks a lot Mario !
