Dear Yvan,
Could you please help me with this issue?
I use version 7.1. I want to monitor some time-averaged variables, it's quite useful for checking convergence.
I added the time-averaged variables in GUI/Postprocessing/Time averages, and ticked the boxes in GUI/Postprocessing/Volume solution control/Monitoring. I think this should work. But in the "monitoring" folder, I can't find the time-averaged data. (I can find time-averaged data in the result, only the monitoring data is missed.)
I don't know if this is a bug in v7.1. Attached please find a small test case to reproduce this issue.
Many thanks,
Ruonan
Cannot find time-averaged data at monitoring points
- Bohn_1995_configB_2D_Ra1E7.cgns
- (9.49 MiB) Downloaded 357 times
- setup.xml
- (11.44 KiB) Downloaded 342 times
Re: Cannot find time-averaged data at monitoring points
I did not check this with your test case, but it looks like a bug that was fixed shortly after release of v7.1:
https://github.com/code-saturne/code_sa ... c885e3d688
So the fix will be in v7.1.1 and v7.2.0 when they are released (7.2.0 should be released in June, but we will release 7.1.1 sooner). The fix is already included in the v7.1 branch on the GitHub mirror.
If your build includes this fix and you still have the issue, then do tell me, so I would check on your test case.
Thank you very much for letting me know. I tried the v7.1 branch on Github, it works well.
Many thanks,
Ruonan
Many thanks,
Ruonan
