Apply ideal gas law for incompressible solver
Ruonan
Post by Ruonan »
Dear developers,
Could you please help me with this question?
Following the heated square cavity tutorial, I used Boussinesq approximation, make density change with temperature. Now I want to make density change with both pressure and temperature, that is the ideal gas law, rho=P/(R*T). I think this may be more accurate than the Boussinesq.
But in the subroutine cs_user_physical_properties.f90, I don't know how to call variable "pressure". The code is shown below, with the part ***Pressure*** that cannot work now and need to be changed.
  if (iscalt.gt.0) then
    ivart = isca(iscalt)
    call field_get_val_s(ivarfl(ivart), cvar_scalt)
  else
    write(nfecra,9010) iscalt
    call csexit (1)
  endif
  ! --- Pointers to density values
  call field_get_val_s(icrom, cpro_rom)
  call field_get_val_s(ibrom, bfpro_rom)
  call field_get_val_s(iprpfl(ibeta), cpro_beta)
  do iel = 1, ncel
    xvart = cvar_scalt(iel)
    cpro_rom(iel) = ***Pressure***/(287.0d0*xvart)
  enddo
Thanks a lot for your help!
Ruonan
Re: Apply ideal gas law for incompressible solver
The following page from the documentation should help you find how to access the pressure variable: https://www.code-saturne.org/documentat ... _dico.html
Ruonan
Post by Ruonan »
Dear Yvan,
Thanks a lot for your help. I coded the ideal gas law into cs_user_physical_properties.f90 and got good results. The code is attached below.
Many thanks,
Ruonan
call field_get_val_s(icrom, cpro_crom)
call field_get_val_s(iprtot, cpro_prtot)
call field_get_val_s(ivarfl(isca(iscalt)), cvar_scalt)
varam = 287.0d0
do iel = 1, ncel
  prestot = cpro_prtot(iel)
  cpro_crom(iel) = (prestot)/(varam*xvart)
enddo
