mesh viscosity in v7
daniele
Post by daniele »
The user guide of v7 says one can modify mesh viscosity for an ALE simulation inside the cs_user_physical_properties.f90 routine, as in previous versions.
Nevertheless, in the online documentation the mesh viscosity is not included among the properties that can be modified inside cs_user_physical_properties.f90.
In previous versions, the "usvima" subroutine was used inside cs_user_physical_properties.f90 to modifty mesh viscosity. Usvima is not available anymore in v7.
Therefore, how can we modify mesh viscosity in v7?
Thank you very much.
Daniele
Re: mesh viscosity in v7
The documentation might be incomplete, but you should be able to modify the mesh viscosity along with physical properties (in C or Fortran), accessing the field by its name.
