Good morning,
I'd like to select a surface (both boundary or internal) in Paraview and calculate the fluid flow (m3/s) by integrating the speed.
I can do it with "slice" and "integrate variables" functions in Paraview but when simulations and slices are several, it becomes annoying and time consuming, so I'd prefer to set the surfaces in Code_Saturne.
The default boundary surfaces save only the surface variables, so the speed is not included.
How can I include the speed?
Thank you.
Lorenzo
Flow through a surface
Re: Flow through a surface
If you select an internal surface, you can use the cs_user_postprocess_values user-defined function (in cs_user_postprocess.c) to add any value you need. For internal faces, I recommend averaging the cell values of the neighboring cells. See examples in the in-line documentation (https://www.code-saturne.org/cms/sites/ ... var_p.html).
