Now I am using CS(version6.0.5) on Linux(version20).
When I try to run a simulation with the paralellization, some errors occurred.
I am not familiar with this.
Would someone give me tips or solutions?
When I run a simulation with 1 process, it worked, but after 2 or more process it did not work.
Tsubasa
Error message is following:
Code_Saturne
Version: 6.0.5
Path: /opt/Code_Saturne-6.0.5/code_saturne-6.0.5/arch/Linux_x86_64
Result directory:
/home/hamada/CFD/TEST/CASE1/RESU/preprocess_20210525-1533_1
Preparing calculation data
Parallel code_saturne on 2 processes.
Preprocessing calculation
Starting calculation
Invalid MIT-MAGIC-COOKIE-1 key/opt/Code_Saturne-6.0.5/code_saturne-6.0.5/arch/Linux_x86_64/libexec/code_saturne/cs_solver: symbol lookup error: /opt/Code_Saturne-6.0.5/code_saturne-6.0.5/arch/Linux_x86_64/lib/libsaturne-6.0.so: undefined symbol: ple_coupling_mpi_name_to_id
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpiexec.openmpi detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[43600,1],0]
Exit code: 127
Post-calculation operations
solver script exited with status 127.
Error in calculation stage.
Problem of MPI?
Re: Problem of MPI?
This looks like an installation issue. Could you provide the info recommended in the installation forum section ? viewtopic.php?f=3&t=12
Re: Problem of MPI?
Hello!
I met the same problem with you these days.The case only can be run with one process and when I set the process number more than one the same error ouccers like:
Parallel code_saturne on 10 processes.
./cs_solver: symbol lookup error: /home/hpc/Code_Saturne/7.0.2/code_saturne-7.0.2/arch/Linux_x86_64/lib/libsaturne-7.0.so: undefined symbol: ple_coupling_mpi_name_to_id
Then I search on this website and found this post.Have you solved this problem?It has been a long time since this problem was posted,but I would be very grateful if you could give me some help or advice!Thank you so much!
Re: Problem of MPI?
Actually, I did not solve this problem at that time, and I did not remember correctly how I solved this.
I guess I re-installed a few times. Then after that, I did not face this problem.
Sorry I cannot give you good answer, but anyway you should provide the info recommended in the installation forum section ? viewtopic.php?f=3&t=12
Tsubasa
Tsubasa
