Which file is read in restart for velocity and pressure?
Tsubasa
Post by Tsubasa »
Now I am wondering which files are read for velocity and pressure when we set restart calculation.
I mean that when we select "check point" in GUI, which files of velocity and pressure are refererred in restart calculation?
In future I will use these files for inverse problem, so I want to know this.
Tusbasa
Luciano Garelli
Re: Which file is read in restart for velocity and pressure?
Post by Luciano Garelli »
Did you check the user guide?
In section 3.9.3.7 Variables saved to allow calculation restarts, you have a detailed description of the saved files in the checkpoint directory and also the variables saved in each file.
Tsubasa
Post by Tsubasa »
As you said, I can find the description for my question.
Let me check just in case.
As far as I understand in Section 3.9.3.7,
"main" file contains variables" value of last time step.
This means, if I need all variables' value at every time step for inverse problem, do I have to use variables' value (such as pressure velocity) in "listing" or "run_solver.log"?
For inverse problem, I will use my code and need variables' value at every time step.
Tsubasa
If you need values over the whole domain at every time step, I recommend you look at i-situ methods. Writing values at each time step has a high impact on performance, and will fill up your storage very quickly.
Tsubasa
Post by Tsubasa »
Do you mean "in-situ method"? or "i-situ method"?
Tsubasa
Sorry for the typo.
"In-situ" methods.
Tsubasa
Post by Tsubasa »
If I need only variables' value of average flow fileld at the las step, where can I get them (velocity and pressure)?
Tsubasa
In this case, the best is to activate time moments (in postprocessing) for velocity and pressure. They should then appear in the checkpoint/auxiliary.csc file.
