BUNDLE Benchmark case
Here is the base benchmark case used for code_saturne on larger machines.
The case's MESH directory contains scripts used to generate the mesh with various refinements using the Salome platform.
For those who do not have access to a Salome build adapted to their platform, the usual "fine mesh" can be downloaded directly from the code_saturne website: https://www.code-saturne.org/cms/sites/ ... h_input.gz. I can then be decompressed and placed in the MESH/F128 directory.
The benchmark is currently set up for code_saturne version 6.1 to 7.0.
The meshes attached directly in this post are very coarse variants, suitable for testing on a workstation.
BUNDLE.tar.gz
v7.0 setup
(16.04 KiB) Downloaded 7910 times
MESH.tar.gz
Coarse meshes
(1.51 MiB) Downloaded 8053 times
BUNDLE.tar.gz
v6.1 setup
(16.09 KiB) Downloaded 7926 times
