Choice of time_scheme - How to modify the parameters?
Gen
Post by Gen »
Dear code saturne team,
Bonjour!
I got below message while performing LES case of tutorial "Code Saturne version 6.0 tutorial:
Turbulence simulation in a mixing tee". I really want to know how to fix this problem.
I have tried with modini.f90 and subroutine usipsu in cs_user_parameter.f90.
But I could only change the value of isto2t :(.
@ @@ WARNING : WHEN READING INPUT DATA
@ CHOICE OF TIME-SCHEME
@ TIME-SCHEME FOR VELOCITY IS SECOND ORDER
@ (THETAV = 0.50E+00)
@ SOME TERMS ARE HOWEVER FIRST ORDER IN TIME WITH
@ THE FOLLOWING SETTINGS:
@ parameters ISTMPF ISNO2T ISTO2T IROEXT IVIEXT ICPEXT
@ Values entered 2 1 0 0 0 0
@ computation will go on.
@ Check the input data given through the User Interface
@ or in cs_user_parameters.f90.
Thank you in advance very much for your attention and your help!
Je vous remercie :)
Re: Choice of time_scheme - How to modify the parameters?
Did you modify some parameters ? Is this an error or just a warning message (i.e. does the code stop or keep running after this message; it seems to indicate it keeps running) ?
Gen
Post by Gen »
Sorry for replying too late. It's just a warning message and it keeps running.
I followed the tutorial step by step so I suppose I didn't modify any parameters.
When I calculated other LES case by myself, I also got this message. I guess it’s because some parameters are not set correctly, though I haven't figured out how to solve it.
Thanks for your help!
