I am facing a problem when I need to verify a example which uses Perry(5 GG) model to calculate the absorption coefficient and so on. Thus I read the cs_user_radiative_transfer file, and I found there were several models could be called like FSCK and ADF.
My question is, when I need to establish a equation concerning of emissivity, absorption coefficient and temperature(my example article had demonstrated the coefficients for the Perry WSGG model in different H2O/CO2 ratios ), whether I can define the absorption coefficient and emissivity(obviously, non-grey) via user-function by connecting with the cells' temperature?
If Code_Saturne indeed supports that, what are the main points should I notice? Or how can I use the cells' temperature given the initialization job is done.
I am a student and new to CS. Sincerely thank you for your generous help
