Does code_saturne use wall functions on standard walls?
Mohammad
Post by Mohammad »
As you know, we may get better results if we set up wall functions boundary condition on walls instead of no-slip condition for turbulent flows.
According to the documents on the Doxygen about iwalf (https://www.code-saturne.org/cms/sites/ ... 69ec058107) it is mentioned that:
5: two scales of friction velocities (mixing length based on V. Driest analysis) iwallf is initialised to 2 for iturb = 10, 40, 41 or 70 (mixing length, LES and Spalart Allmaras).
iwallf is initialised to 0 for iturb = 0, 32, 50 or 51
Does it mean that code_saturne implements log-law wall function boundary condition on walls (with the iparoi condition) for LES by default or we have to set it in cs_user_parameters file to 5 or 2?
Mohammad
Re: Does code_saturne use wall functions on standard walls?
For RANS models, that is the default, but for LES I am not sure. If someone can correct me I would be happy.
If in doublt, you can simply run 1 (or 0) time steps with a simple case and check in the setup.log and run_solver.log which values the code has used for iwallf. Looking at src/modini.f90 it would seem iwallf ss set to 2 by default if the user has not specified it in the GUI or in cs_user_parameters.
So the documentation seems good.
But whenever in doubt or suspecting a bug, do not forget to experiment and use the logs on a simple case. This will often give you the quickest answer.
Mohammad
Post by Mohammad »
Thank you Yvan!
I checked the setup.log file and noticed that the default value is set to 2 which means that code_saturne uses one scale of friction velocities (log law) for LES by default.
Mohammad
Ruonan
Post by Ruonan »
Hello Yvan and Mohammad,
Please I have a question about this topic:
I am also doing LES in Code_Saturne, and I confirmed from my setup.log file, that iwallf is initialized to 2 (one scale model log law) for LES Smagorinsky and classical dynamic model.
But how could I do if I want a wall resolved LES? I found there is no option for "wall function type" for LES in GUI. Also, as the wall function is "initialized" to "one scale model log law", will there be a change in the solution? For example, if I use a mesh that is fine enough, will it be initialized to "one scale model log law" and turn to "No wall function" during the calculation?
Many thanks,
Ruonan
Ruonan
Post by Ruonan »
Hello Code_Saturne experts,
Please could you give me some advice?
Many thanks,
Ruonan
I would prefer turbulence specialists to answer this in a more precise manner, but if you want to ensure wall laws are not used, you can use cs_user_coundary_conditions to impose a Dirichlet condition (icodcl(ifac,iu) = 1) with zero velocity (rcodc(ifac, iu, 1) = 0, same for iv and iw).
Ruonan
Post by Ruonan »
Thanks for your reply. Actually I tried to set a Dirichlet boundary condition in the subroutine, but had some problems:
For example, for a stationary wall, if I don't specify anything either in GUI or subroutine, the velocity on the wall seems to be a friction velocity with wall functions, not no-slip velocity, but other values (pressure, temperature, etc) seem ok. But if I specify a Dirichlet boundary condition in subroutine as you said, the velocity on the wall seems no-slip without wall functions, but the problem is: wall distance and other values in the fluid domain seem wrong.
This is also discussed in a previous post, which hasn't been replied to now.
viewtopic.php?f=2&t=2791
Please could you give me some tips on what caused this problem? Thank you!
Ruonan
