Hi everyone !
When I run a simulation of a cross flow over a cylinder, it only runs till the 50 000th iteration (out of 500 000 in total) and then stops leaving plenty of files of the type "error_rXXXX". XXXX vary from '0000' to a high number like '1400', it depends on the number of processors. And every of those files are empty
I already succesfully run such simulations but I got this type of error for the last simulations. I have enough storage left. The job.err.log file is ok, and no error message are in the result directory can help me
I can provide any information needed.
Lot of files "error_r****" and simulation stops every N iterations
Re: Lot of files "error_r****" and simulation stops every N iterations
If the error* files are empty (they should contain backtraces) you might have sole info on errors on the batch output or error log file. If a single error_r* file us non-empty that would be interesting.
Do you have user functions ? A specific output at 50000 iterations ? Doea the end of the run_solver.log/listing file contain useful info ?
Hello
Tank you for your quick reply !
I have indeed a user function which is the cause of my problem : the simulation runs correctly without it.
I join the user function file and the batch error file which mainly says "segmentation fault".
The user function should print in the listing file the mean velocity of control aeras around a cylindrical geometry.
- job_4423890.err.log
- (2.53 KiB) Downloaded 388 times
- cs_user_postprocess_mt.f90
- (10.42 KiB) Downloaded 407 times
Did you test this user subroutine on a smaller case on a workstation ? Ideally using a debug build ? This is the best practice, and usually make debugging much easier than on a large case with a batch system (even with good parallel debuggers such as DDT or TotalView, limiting "cluster debugging" to otherwise hard to reproduce cases is often a better use of resources).
