Post-process uet and uk
Posted: Mon Jul 06, 2020 3:41 pm
by Ionut G
I am running k-omega SST, with no wall function, simulations on a straight channel.
I need to save to the post-processing results the friction velocities uet(ustar) and uk.
From the forum discussions I understand that I need to use the "cs_user_postprocess_var.f90" file in order to save the friction velocities.
I modified the "cs_user_postprocess_var.f90" file from examples.
The simulation runs good until the writing of the results file, where I receive the SIGSEGV error:
** Writing the auxiliary restart file
Start writing
End writing the dimensions and options
End writing the physical properties
End writing the time step
Wrote boundary condition coefficients to checkpoint: checkpoint\auxiliary
End writing the wall distance
End writing
How can I solve this issue?
I attached the listing and the cs_user_postprocess_var.f90 files.
Any help is greatly appreciated.
Thank you,
Ionut
Re: Post-process uet and uk
Posted: Mon Jul 06, 2020 6:42 pm
Did you try running under a debugger ? Or proofreading your files ?
If you declare uet as a pointer but do not initialize it, a crash is to be expected.
Posted: Tue Jul 07, 2020 3:34 pm
by Ionut G
Thank you very much for your support!
I tried to initialize uet, but I keep having the same error SIGSEGV signal, as in the first post.
Could you give me some more guidance or some examples on how to save variables from cs_wall_functions.h subroutine?
I attached the files that I am using: clptur.f90, cs_user_postprocess_var.f90, cs_user_initialization.c.
Thank you Very much,
Ionut
Posted: Wed Jul 08, 2020 11:39 am
You are still not initializing the uetbor array which you are using in cs_user_postprocess_var.f90.
