Post-process uet and uk
Ionut G
Post by Ionut G »
Hello everyone,
I am running k-omega SST, with no wall function, simulations on a straight channel.
I need to save to the post-processing results the friction velocities uet(ustar) and uk.
From the forum discussions I understand that I need to use the "cs_user_postprocess_var.f90" file in order to save the friction velocities.
I modified the "cs_user_postprocess_var.f90" file from examples.
The simulation runs good until the writing of the results file, where I receive the SIGSEGV error:
** Writing the auxiliary restart file
Start writing
End writing the dimensions and options
End writing the physical properties
End writing the time step
Wrote boundary condition coefficients to checkpoint: checkpoint\auxiliary
End writing the wall distance
End writing
How can I solve this issue?
I attached the listing and the cs_user_postprocess_var.f90 files.
Any help is greatly appreciated.
Thank you,
Ionut
(9.64 KiB) Downloaded 408 times
listing.txt
(38.9 KiB) Downloaded 399 times
Re: Post-process uet and uk
Did you try running under a debugger ? Or proofreading your files ?
If you declare uet as a pointer but do not initialize it, a crash is to be expected.
Ionut G
Post by Ionut G »
Thank you very much for your support!
I tried to initialize uet, but I keep having the same error SIGSEGV signal, as in the first post.
Could you give me some more guidance or some examples on how to save variables from cs_wall_functions.h subroutine?
I attached the files that I am using: clptur.f90, cs_user_postprocess_var.f90, cs_user_initialization.c.
Thank you Very much,
Ionut
(9.66 KiB) Downloaded 434 times
clptur.f90
(100.9 KiB) Downloaded 386 times
(3.87 KiB) Downloaded 420 times
You are still not initializing the uetbor array which you are using in cs_user_postprocess_var.f90.
