YETI is one of the top cooler brands in the world. While YETI products are admittedly not cheap, they are worth every cent of your money. YETI coolers have unique features that deliver superior performance. They also come in a variety of sizes and types that fit different needs.
After checking a large number of cooler reviews and ratings, we compiled this list of Top Rated Coolers For Camping by YETI. If you need to carry a cooler with you regularly or if you are merely a fan of YETI coolers, we know you won’t want to miss this list.
1. YETI Roadie 20
The YETI Roadie 20 is a travel cooler that provides a capacity of 14 cans. In case you are using it for barbecue food, the cooler can store a maximum of 20 pounds of ice, promising to keep your food cold until it is time to prepare for cooking. It is among the best coolers for keeping ice. The Yeti Roadie 20 can hold ice for at least 72 hours thanks to its PermaFrost insulation and Interlock form-fitting barrier. Made of high–quality plastic and equipped with their patented Neverfail hinge system, the cooler is bear-resistant and can withstand any challenge. It also comes with four non-slip feet to prevent slipping and sliding and a draining system to drain out melted ice.
2. YETI Tundra 65 Cooler
The YETI Tundra 65 Cooler is the most appropriate option when you are preparing for a family camping trip. With a capacity of 42 cans, this cooler has incredible space to carry anything you need for the trip. It also comes with a separate dry basket that can be used to store food and drinks, meaning your stuff will not be submerged in ice. Similar to the YETI Roadie 20, the YETI Tundra 65 utilizes PermaFrost insulation to hold ice for days and the Neverfail hinge system to prevent hinges from breaking. The cooler comes with Bearfoot feet to avoid slipping and its Anchorpoint tie-down slots for you to secure it to your car or boat.
Check Here: Unlock the Mystery: The Best Coolers on the Market
3. YETI Hopper Two Portable Cooler
The Yeti Hopper Two is the best soft-sided cooler that resembles a classic handbag with wide zipper access so that you can place it under your arm. If you use it to keep ice only, then it can hold up to 30 pounds of ice; otherwise, it can fit up to 24 cans with enough ice to keep them cold. Although its walls are not thick, the cooler is equipped with ColdCell insulation that allows ice retention for 24 hours. The product is made of DryHide material, which is not only waterproof but also puncture-resistant. This cooler also comes with six modified D-rings used to attach accessories and the highest quality webbing straps.
4. YETI Hopper Flip Cooler
The YETI Hopper Flip is a small and stylish cooler that you can bring anywhere, even on an airplane. With a 12-can capacity, this compact cooler is perfect for a single day trip for a couple. The cooler delivers superior performance thanks to the combination of DryHide shell and PermaFrost insulation, enabling it to have longer ice life compared to other same-sized coolers. The Hopper Flip’s structure allows for puncture resistance as well as mildew resistance. The model also comes with several attachments, such as a Zinger bottle opener and ice packs.
We hope that the information provided was helpful, and ideally, you can make your decision after going through the list of the Best Coolers In The World. Comment to let us know if you have experience using any of the mentioned models. Also, we would love to hear if you have other great options in mind.
