Second inlet zone looks like first inlet
Ben
Post by Ben »
Hi all,
I created similar model in Code-Saturne and tried to calculate it. But I have error where it tells that my second inlet has one face, but in fact zones are different.
The error is below:
/home/code_saturne_5/code_saturne-5.0.12/src/base/cs_boundary_zone.c:479: Fatal error.
Boundary zone 2 ("Inlet_gas") contains at least
one face already marked with zone id 1 ("Inlet").
Check definitions or allow overlays for this zone.
1: 0x7f9bf646af4a <cs_boundary_zone_build_all+0x33a> (libsaturne-5.0.so)
2: 0x7f9bf64c696f <cs_preprocess_mesh+0x3bf> (libsaturne-5.0.so)
3: 0x7f9bf6404511 <cs_run+0x181> (libsaturne-5.0.so)
4: 0x7f9bf6404243 <main+0x113> (libsaturne-5.0.so)
5: 0x7f9bf5dcc830 <__libc_start_main+0xf0> (libc.so.6)
6: 0x400729 <_start+0x29> (cs_solver)
Could anybody advise about possible decision?
Thanks in advanse
Re: Second inlet zone looks like first inlet
Did you visualize the BC errors to see where you have overlap ? You may also, in "preprocessing mode", generate extra postprocessing boundary meshes matching each of your selection criteria, and seeing where those overlap.
Ben
Post by Ben »
Hi Yvan.
Thanks for advise.
I'm new user of Code Saturne. Try to check these points.
