Syrthes insatllation
misomg
Post by misomg »
I am trying to install Syrthes 4.3.5 on Ubuntu 20.04 as guest in VMware Player. It seems there is some problem with mpi, but I cannot find where.
Attached are setup file, and error log.
Would be great, if anyone could advice some solution.
Michal
setup.ini
(4.24 KiB) Downloaded 996 times
ERREUR.log
(4.02 KiB) Downloaded 1003 times
Re: Syrthes insatllation
Is MPI (and the associated headers) installed correctly on your system ? Note we recently added a list of packages needed for code_saturne on various distributions on various systems here : https://github.com/code-saturne/code_sa ... n-packages
Also, did you use the old Syrthes package from the EDF R&D website, or the updated one from this website (https://www.code-saturne.org/cms/download/prerequisites) ? it may not make a difference for MPI, but will for Python and the graphical user interface.
misomg
Post by misomg »
thank you for support. I used updated package from Code Saturne prerequisites site.
Somewhere on this forum I found that one solution could be change compiler to
compC   mpicc
compCX mpicxx
and my path to openmpi was wrong. The right one is
/usr/bin
Now installation and test case finished fine
Michal
