Code_Saturne tutorial simple junction
xsh
Post by xsh »
I followed the tutorial step by step, and there was an error when I executed the command“$ cd simple junction/MESH/
$ cp /projets/echanges.004/ITECH CS TRAINING/meshes/1-simple junction/downcomer.des .”
“/projets/echanges.004/ITECH CS TRAINING/meshes/1”There is no file or directory.
When installing code_Saturne I only installed compilers for C/C++/Fortran (such as the GNU compiler collection) ,a Python interpreter and pyqt5 for gui.
What's the problem?
Re: Code_Saturne tutorial simple junction
Perhaps you need to adapt the directory paths in the example to the ones really on your system ? The tutorial should mention this is an example. The mesh files are available in the "examples" subdirectory of the code_saturne sources.
