AFM
s marco
AFM
Post by s marco »
I am trying to validate a different AFM in version 6. To do that I changed coefficients xiafm, etaafm, cthafm in the subroutine cs_turboulence_model.c, please find it attached.
That works in code_saturne_4 but in code_saturne_6 I got errors in compile stage, please find it in compile.log.
Is there for version 6 a different cs_turbulence_model.c that I am not able to find it or in the new version something works differently?
Marco
compile.log
(12.28 KiB) Downloaded 467 times
(31.94 KiB) Downloaded 457 times
Re: AFM
Yes, using a modified non-user file such as cs_turbulence_model.c from one version to another has about a 0.2% chance of working, and is definitely not recommended, so what you need to do is apply the changes to a version of the file based on version 6.0. If you work directly on a git checkout is is easy because you can merge a change from one branch to another or use "git format-patch" to extract a diff and "git am" to apply it to another branch or even clone.
