Turbulent Prandtl number
s marco
Post by s marco »
how can I change the turbulent Pr number in my setup for code saturne 6?
I' ve only found advises about sigmas but it seems be available only in older version.
Thanks in advance,
Marco
Re: Turbulent Prandtl number
The turbulent Schmidt (sigmas) is still available, as a field keyword, "turbulent_schmidt".
In C,
value = cs_field_get_key_double(f, cs_field_key_id("turbulent_schmidt"));
or
cs_field_set_key_double(f, cs_field_key_id("turbulent_schmidt"), value);
s marco
Post by s marco »
Thanks a lot.
In which subroutine should I specify this value?
Kind regards,
Marco
cs_user_parameters should do.
