Parallel computation of loops
Mohammad
Post by Mohammad »
I have the following loop in cs_user_extra_operations.c file:
  for (cs_lnum_t i = 0; i < n_faces; i++) {
    face_id = face_list[i];
    iel = b_face_cells[face_id];
    Tau_Wall_Mean +=  Tau_wall[iel];
  FILE *f1 = NULL;
     f1 = fopen("MEAN_SHEAR.dat","a");
     fprintf(f1, "%i\t%f\n", ntcabs, Tau_Wall_Mean/n_faces);
     fclose (f1);
This code calculates a variable(Tau_Wall_Mean) in a loop and then writes it to a file(MEAN_SHEAR.dat). I use 8 cores for processing.
When I open the exported file, It gives me 8 different values at each time step number which means that each core is computing (maybe a part of) the loop separately and gives a different value and the code does not collect the result from the cores.
How can I force the loop to collect the results from all cores and give me just one number?
Does this problem occur just for the loops which a variable should be summed by its previous value?
CS version: 5.0.9
Mohammad
Re: Parallel computation of loops
Are you using MPI or OpenMP parallelism ?
There are user examples handling parallelism at least for MPI, so check the cs_user_extra_operations variants.
Mohammad
Post by Mohammad »
Hello and thank you!
I use MPI.
I checked all those files it's a bit confusing. Some of them use this condition to write only one output at each time step so I used it and it worked:
if (cs_glob_rank_id <= 0)
I don't know what is cs_glob_rank_id and it also doesn't have a definition in doxygen.
There's just a comment above one of them which says:
/* Only process of rank 0 (parallel) or -1 (scalar) writes to this file. */
and also some examples use the following command at the end of a summing loop which seems to sum all values on all processors, so, I added it to my code:
cs_parall_sum(1, CS_FLOAT, &Tau_Wall_Mean);
When I use those codes, It gives me different output averages for different number of cores! For example if I use 8 cores the average of my outputs becomes 0.8. If I use 4 cores it becomes 0.2 and for single core its -0.0002!
It's really confusing!
My modified code is now:
if (cs_glob_rank_id <= 0){
  FILE *f1 = NULL;
     fclose (f1);
Mohammad
Luciano Garelli
Post by Luciano Garelli »
cs_glob_rank_id will give you the rank of a MPI process in case of parallelism and it will take the values between 0<=cs_glob_rank_id< number of process. In case of a serial run cs_glob_rank_id =-1, so only process of rank=0 (parallel) or -1 (serial) will write to this file.
In you code, the n_faces will give you the local number of faces, so if you need to compute an average over the faces you have to do the parellel sum of n_faces to get the total number of faces, or divide Tau_Wall_Mean/n_faces after the loop before writting. If you need Tau_Wall_Mean just write it without divide by n_faces.
Mohammad
Post by Mohammad »
Thank you very much Lucian, your helps solved the problem.
Mohammad
