SIGSEGV signal writing results in extra operations
antoineb
Post by antoineb »
Hi there,
After a successfull instalaltion of Code_saturne 6.0 a few weeks ago, I went at it again, downloaded the last version (September 26th) but on the first run of a previously working case, i had the following error :
   1: 0x7fe6ae13b924 <fclose+0x4>                     (libc.so.6)
   2: 0x7fe6afd0b0b1 <cs_run+0x421>                   (libcs_solver-6.0.so)
   3: 0x7fe6afd0ab8d <main+0x19d>                     (libcs_solver-6.0.so)
   4: 0x7fe6ae0e0b6b <__libc_start_main+0xeb>         (libc.so.6)
   5: 0x555ff7e1f0ea <_start+0x2a>                    (cs_solver)
I looked at the listing and, the calculation finishes with no issue because I have all the timesteps and the :
                 FINAL STAGE OF THE CALCULATION
It seems to fail when saving the calculation.
Any idea where this might come from ? I tried running it again on my other computer, with a previous version of CS6.0, it worked fine. Any chance you have a link to the previous version (that I did not save...)
Antoine
antoineb
Re: SIGSEGV signal writing results in extra operations
Post by antoineb »
Ok I found the problem, but can't seem to solve it...
It's related to extra operations done after calculation is finished in cs_user_extra_operations.c
The segmentation fault comes from the fclose() function that seems to consider the pointer to the file is NULL.
What am I doing wrong ?
Here is my cs_user_extra_operations.c :
BEGIN_C_DECLS
 * Local Macro definitions and structure definitions
static FILE *f1 = NULL;
 * User function definitions
void
cs_user_extra_operations_initialize(cs_domain_t     *domain)
  const cs_mesh_t *m = domain->mesh;
  const cs_mesh_quantities_t *mq = domain->mesh_quantities;
  const int n_cells = m->n_cells;
  if (cs_glob_rank_id < 1) { /* Only the first rank write something */
    f1 = fopen("velocity_roof.dat","a");
    fprintf(f1,"# N, Time, Mean_vel\n");
void
cs_user_extra_operations(cs_domain_t     *domain)
  /* Local variables */
  int nt_cur = domain->time_step->nt_cur;
  const cs_real_t *cell_vol = mq->cell_vol;
  const cs_zone_t *z = cs_volume_zone_by_name("roof");
  /* Get physical fields */
  const cs_real_3_t *vel = (cs_real_3_t *)CS_F_(vel)->val;
  cs_real_t norm_vel = 0.;
  /* Loop over elts of the zone */
  for (cs_lnum_t elt_id = 0; elt_id < z->n_elts; elt_id++) {
    const cs_lnum_t cell_id = z->elt_ids[elt_id];
    norm_vel += cs_math_3_norm(vel[cell_id]) * cell_vol[cell_id];
  /* Sum of values on all ranks (parallel calculations) */
  cs_parall_sum(1, CS_DOUBLE, &norm_vel);
  norm_vel /= z->measure;
  /*  Write
    fprintf(f1,"%10d %12.8e %12.8e\n",
        domain->time_step->nt_cur,
        domain->time_step->t_cur,
        norm_vel);
void
cs_user_extra_operations_finalize(cs_domain_t     *domain)
    fclose(f1);
END_C_DECLS
When I comment all the writing-to-file parts, it gives no error.
Does it sound familiar ?
Antoine
antoineb
Post by antoineb »
To be even more specific, with the help of a much more CS qualified person, I came to the point where cs_user_extra_operations() and cs_user_extra_operations_initialize() don't seem to be called during calculation.
That would explain the segmentation fault because, the file was simply never created and the pointer was indeed NULL.
Antoine
This is strange. cs_user_extra_operations_finalize is called directly by C code, while the other 2 cs_user_extra_operations_* functions may be called through Fortran, so I suspect i subtle installation (or reinstallation) issue.
Did you simply overwrite your previous installation, or did you start from a new build directory ? Did you have a some other change in your system (i.e. upgrade) during that time ? What system are you running on ?
antoineb
Post by antoineb »
I'm running on an ubuntu 19.04 VM. The fortran compiler is f95 and the c compiler is cc.
Martin Ferrand told me that user_extra_operations_initialize() is called by inivar.f90 indeed. He advised me to make a copy of the file, insert a bit of print code and recompile with --enable-debug in order to see if the subroutine is called during computation.
Anyway I think I'm going to do a clean install to see if the problem still happens.
I'll let you know !
Thanks,
Antoine
antoineb
Post by antoineb »
Hello again,
After two clean installs (with f95 and gfortran as f compiler) I still have issues.
I inserted a simple : write(nfecra,*) “here we are”
Just before the call to user_extra_operations_initialize() in inivar.f90, and i do get the "here we are" line in the listing.
With this basic cs_user_extra_operations.c, only the finalize() function gets called...
Is my syntax ok ?
Is it possible that the C bindings aren't working ?
Another precision : I'm building without the gui.
Antoine
edit : it works well on a locally installed ubuntu 19.04. I'm guessing the issue is on the cloud VM, but I see no difference between the two configs (same gcc, same python, same version of ubuntu, same code_saturne, same setup file)
(4.39 KiB) Downloaded 317 times
Since you can install the code, a good test in my opinion would be to modify the cs_user_extra_operations.c from the main sources, then reinstall and see how it behaves. This will allow determining whether the call site is never reached for some reason or whether the default user function is not replaced by the one from the case you are running (we have already seen strange things on Ubuntu, but so far only in the packaged install").
antoineb
Post by antoineb »
Finally got it working on a google cloud VM, but on Debian 9.11 instead of Ubuntu 19.04...
I did everything exactly the same, but all the subroutines and post calculation operations are ok now !
Antoine
