Error in compiling subroutines - Code Saturne 5.2
In order to learn how to use subroutines in Code_Saturne, I am doing Full Domain tutorial (case2)
However I have an error message when I try to run calculation in Code_Saturne
Here's the message obtained with code_saturne compile :
The version of Code_Saturne is Code_Saturne 5.2 from Salome_CFD (Development version)
Thank you for your help
gfortran -o cs_f_user_boundary_conditions.o -I /home/jarancio/salome-cfd/Salome_CFD-SCFD_V8_5_0-Code_Saturne-5_2-univ_d54f597c/modules/CFDSTUDY_v52/include/code_saturne -x f95-cpp-input -Wall -pedantic-errors -std=f2003 -fopenmp -O -c /home/jarancio/Simulations_CodeSaturne/fulldomain/case2/SRC/cs_user_boundary_conditions.f90
File "/home/jarancio/salome-cfd/Salome_CFD-SCFD_V8_5_0-Code_Saturne-5_2-univ_d54f597c/modules/CFDSTUDY_v52/bin/code_saturne", line 76, in <module>
retcode = cs.execute()
File "/home/jarancio/salome-cfd/Salome_CFD-SCFD_V8_5_0-Code_Saturne-5_2-univ_d54f597c/modules/CFDSTUDY_v52/lib/python2.7/site-packages/code_saturne/cs_script.py", line 91, in execute
File "/home/jarancio/salome-cfd/Salome_CFD-SCFD_V8_5_0-Code_Saturne-5_2-univ_d54f597c/modules/CFDSTUDY_v52/lib/python2.7/site-packages/code_saturne/cs_script.py", line 138, in compile
return cs_compile.main(options, self.package)
File "/home/jarancio/salome-cfd/Salome_CFD-SCFD_V8_5_0-Code_Saturne-5_2-univ_d54f597c/modules/CFDSTUDY_v52/lib/python2.7/site-packages/code_saturne/cs_compile.py", line 643, in main
keep_going=keep_going)
File "/home/jarancio/salome-cfd/Salome_CFD-SCFD_V8_5_0-Code_Saturne-5_2-univ_d54f597c/modules/CFDSTUDY_v52/lib/python2.7/site-packages/code_saturne/cs_compile.py", line 608, in compile_and_link
stderr=stderr)
File "/home/jarancio/salome-cfd/Salome_CFD-SCFD_V8_5_0-Code_Saturne-5_2-univ_d54f597c/modules/CFDSTUDY_v52/lib/python2.7/site-packages/code_saturne/cs_compile.py", line 569, in compile_and_link
keep_going, stdout, stderr)
File "/home/jarancio/salome-cfd/Salome_CFD-SCFD_V8_5_0-Code_Saturne-5_2-univ_d54f597c/modules/CFDSTUDY_v52/lib/python2.7/site-packages/code_saturne/cs_compile.py", line 431, in compile_src
stdout=stdout, stderr=stderr) != 0:
File "/home/jarancio/salome-cfd/Salome_CFD-SCFD_V8_5_0-Code_Saturne-5_2-univ_d54f597c/modules/CFDSTUDY_v52/lib/python2.7/site-packages/code_saturne/cs_exec_environment.py", line 536, in run_command
p = subprocess.Popen(cmd, universal_newlines=True, env = env, **kwargs)
File "/home/jarancio/salome-cfd/Salome_CFD-SCFD_V8_5_0-Code_Saturne-5_2-univ_d54f597c/prerequisites/Python-2710/lib/python2.7/subprocess.py", line 710, in __init__
errread, errwrite)
File "/home/jarancio/salome-cfd/Salome_CFD-SCFD_V8_5_0-Code_Saturne-5_2-univ_d54f597c/prerequisites/Python-2710/lib/python2.7/subprocess.py", line 1335, in _execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
stderr=stderr)
errread, errwrite)
- setup.xml
- (13.21 KiB) Downloaded 724 times
- compile.log
- (354 Bytes) Downloaded 736 times
- (20.97 KiB) Downloaded 711 times
Re: Error in compiling subroutines - Code Saturne 5.2
Is gfortran installed on your machine ?
It wasn't
I have just installed it with apt-get install gfortran-8
However I have got the same error message when I run calculation
do you have a "gfortran" executable or only "gfortran8" ? This may depend on your distribution.
Could you post your new compile.log ? You might have a similar but slightly different issue if some other tool is missing.
I downloaded only gfortran8
Here's the new compile.log
stderr=stderr)
errread, errwrite)
stderr=stderr)
errread, errwrite)
Again: does the "gfortran" command work on your machine now ?
gfortran command works on my machine
Here's a test :
jarancio@arancio:~/Bureau$ ls
boarding-pass.pdf 'Reprenez le contrôle avec Linux'
hello.f90 Salome-CFD_SCFD_V8_5_0.desktop
jarancio@arancio:~/Bureau$ gfortran-8 hello.f90 -o hello
hello Salome-CFD_SCFD_V8_5_0.desktop
hello.f90
Jérémy
Here's a test :
hello.f90
Jérémy
- hello.f90
- (56 Bytes) Downloaded 732 times
Could you also check if gfortran works when run under "salome shell" ?
If it is not related, we would need to modify a salome_cfd file to instrument it, but starting with the simplest test first may be better...
Yes it works too :
[NS=no_host:no_port]$ gfortran-8 hello.f90 -o hello
[NS=no_host:no_port]$ ls
boarding-pass.pdf hello hello.f90 'Reprenez le contrôle avec Linux' Salome-CFD_SCFD_V8_5_0.desktop
Jérémy
Jérémy
A further test would be to edit "/home/jarancio/salome-cfd/Salome_CFD-SCFD_V8_5_0-Code_Saturne-5_2-univ_d54f597c/modules/CFDSTUDY_v52/lib/python2.7/site-packages/code_saturne/cs_exec_environment.py",
line 536, replacing:
with:
(i.e. inserting a print command) to check which exact command causes the issue.
print(cmd)
