Backtrace_SIGSEGV signal
C0st4s
Post by C0st4s »
Hope you are well.
What is the easiest way to trace the array that is causing SIGSEGV signal (forbidden memory area access) intercepted! in cs? I am writing some module routines and I am trying to find the root of the error.
Costas
Re: Backtrace_SIGSEGV signal
First, use a version compiled in debug mode.
Second, check backtraces (not always exploitable to the last line, but usually helpful).
Finally, run "cs_solver" under a debugger, such as gdb. Checking the code under Valgrind is highly recommended (note the GUI advanced run settings page helps you run under a debugger, so check it).
If you have not already done so, this usually saves you orders of magnitude in time. This is recommended even when the code seems to work, because "hidden errors" may come back to bite you later, and the earlier they are detected, the less time wasted...
C0st4s
Post by C0st4s »
Dear Yvan,
Thanks a lot for the quick reply. I had a division by zero
Costas
