msh preprocessing error
roberto.bernetti
Post by roberto.bernetti »
Hi
I'm try to run my first simulation in code_saturne.
I prepared a simple mesh with Gmsh, then trying to use the preprocessor to import the mesh.
this is the log file I got:
  |   Code_Saturne Preprocessor  |
  code_saturne version 5.0.9   (built 09/26/18 18:45:31)
  CGNS 3.1.4 file format supportThe description of point <2> was expected in the form "label x y z".
  MED 3.2.0 (HDF5 1.8.12) file format support
  Reading of compressed files ('.gz') with Zlib 1.2.8
  Gmsh format version:     4.1
  Size given for real numbers: 8
../../../../src/code_saturne-5.0.9/preprocessor/pre-post/ecs_pre_gmsh.c:346: Fatal error.
Error decoding line 31 of file
"C:......Gmsh\NaturalConvection.msh" :
I appreciate any hint.
Roberto
Saluti
Roberto
Re: msh preprocessing error
Which version of Gmsh was the file exported from ? The Gmsh file format ha changed recently, so you may need either to use a more recent version of Code_Saturne (in you case, compiling it from the GitHub branch, as 5.0.10 is not released yet, but the updates for Gmsh are ready), or export to Gmsh v2 format.
roberto.bernetti
Which version of Gmsh was the file exported from ?.....
the last one 4.2.3.
I'll try your hint, to use v2 format.
Please do you know the version of Gmsh compatible with code_saturne 5.0?
Saluti
Roberto
The version compatibility is explained in my previous post. Basically, force Gmsh output to V2 format for all releases of Code_Saturne older than last week (there was an initial update a few months ago bug Gmsh checnged their format again from 4.0 to 4.1, so you will only get compatibility with that compiling Code_Saturne from GitHub branches (master, v6.0, v5.3, v5.0). With downloaded .tar.gz (tarballs), you will only get v2 format.
roberto.bernetti
Yvan Fournier wrote: Thu Apr 18, 2019 10:25 am Hello,
The version compatibility is explained in my previous post. Basically, force Gmsh output to V2 format....
Thank you it worked forcing to Version 2
Saluti
Roberto
