Mapped Inlet
akshatm
Mapped Inlet
Post by akshatm »
Halo,
I am running a T-junction case with v5.1.3, where I would like to add mapped inlets at the two inlets. With the 'Mapped Inlet' option available in the GUI, this task becomes simple. However, I receive the following error when setting up one of the mapped inlets.
cs_gui_util.c:819: Fatal error.
Several text node found: 2
The first one is 0
Xpath: /Code_Saturne_GUI/boundary_conditions/inlet/mapped_inlet/translation_y/text()
What I understand from this error is that there exists some text (non-numeral characters) where it expected the translation vector. Is that correct? The translation vector I used for mapping was (0, -0.25, 0). Does it not accept a negative vector?
Setting up the other mapped inlet, with translation vector (0, 0, 0.25), does not generate the above error.
Thanks!
setup.xml
(9.62 KiB) Downloaded 318 times
Re: Mapped Inlet
I just checked this, and this is a bug. We test the presence of mapped inlets globally, where it should be tested on a local (per-boundary-condition) basis. So with a single mapped inlet, things are fine, but with 2, the second one is not handled correctly).
I have a fix for versions 6.0-beta and 5.3, I'll see if I can fix older versions (5.0, 5.3, and 5.2; since 5.1 is not maintained anymore, we won't be releasing any new 5.1 versions, so adapting the fix (which should appear no later than tomorrow on the GitHub mirror) or upgrading to 5.3 would be recommended.
I may to post the patch here, so you can try to patch v5.1 directly, so check again in a few hours.
Re: Mapped Inlet
To fix the bug, in the source tree, in src/gui/cs_gui_boundary_conditions.c, line 248 (in the _mapped_inlet function), replace:
      cs_xpath_add_element(&path, "boundary_conditions");
      cs_xpath_add_element(&path, "inlet");
with:
      cs_xpath_add_elements(&path, 2, "boundary_conditions", "inlet");
      cs_xpath_add_test_attribute(&path, "label", label);
Then recompile/install.
Best regards and thanks fro the bug report.
akshatm
Re: Mapped Inlet
Post by akshatm »
Thanks a lot, Yvan!
