Error opening file: "residuals.csv"
Posted: Tue Apr 02, 2019 2:18 pm
Dear CS experts
I am new to CS and trying to run a small case on Code Saturne which is recently installed on our cluster.
While I run the case on one node (28 CPUs) it worked good but If I run the same setup on multiple nodes it stops with following error :
"System error: Remote I/O error
/work/projects/Code_Saturne/src/code_saturne-5.0.9/src/base/cs_time_plot.c:362: Fatal error.
1: 0x2b2ddafc5d48 <cs_time_plot_init_probe+0x1568> (libsaturne.so.5)
2: 0x2b2ddaf63e3d <cs_log_l2residual+0x46d> (libsaturne.so.5)
3: 0x2b2ddaed8b74 <caltri_+0x2514> (libsaturne.so.5)
4: 0x2b2ddaea933f <cs_run+0x56f> (libsaturne.so.5)
5: 0x2b2ddaea8c8f <main+0x12f> (libsaturne.so.5)
6: 0x2b2ddf46fb35 <__libc_start_main+0xf5> (libc.so.6)
7: 0x400919 <> (cs_solver)
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 46"
Can you please help me to resolve it.
I attached the RESULT folder for both cases
RUN1.zip= failed on 2 nodes
RUN2.zip= OK on 1 node
Amit
Amit
