Error opening file: "residuals.csv"
amitraj2385
Post by amitraj2385 »
Dear CS experts
I am new to CS and trying to run a small case on Code Saturne which is recently installed on our cluster.
While I run the case on one node (28 CPUs) it worked good but If I run the same setup on multiple nodes it stops with following error :
"System error: Remote I/O error
/work/projects/Code_Saturne/src/code_saturne-5.0.9/src/base/cs_time_plot.c:362: Fatal error.
1: 0x2b2ddafc5d48 <cs_time_plot_init_probe+0x1568> (libsaturne.so.5)
2: 0x2b2ddaf63e3d <cs_log_l2residual+0x46d> (libsaturne.so.5)
3: 0x2b2ddaed8b74 <caltri_+0x2514> (libsaturne.so.5)
4: 0x2b2ddaea933f <cs_run+0x56f> (libsaturne.so.5)
5: 0x2b2ddaea8c8f <main+0x12f> (libsaturne.so.5)
6: 0x2b2ddf46fb35 <__libc_start_main+0xf5> (libc.so.6)
7: 0x400919 <> (cs_solver)
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 46"
Can you please help me to resolve it.
I attached the RESULT folder for both cases
RUN1.zip= failed on 2 nodes
RUN2.zip= OK on 1 node
Amit
RUN1.zip
(1.46 MiB) Downloaded 756 times
Re: Error opening file: "residuals.csv"
Could you check with the attached file (adding it in the SRC folder of your case is OK for a first test, and it it works, replacing the one in the code sources and reinstalling is the clean solution) ? It seems the file was opened for all processors (whre it s not necessary), so tricky things can happen based on your file system.
cs_log_iteration.c
(51.52 KiB) Downloaded 783 times
amitraj2385
Thanks Yvan.
It is working with the file.
Ok great. The fix has been commited to development and active maintenance branches, so will be included in 5.0.10, 6.0, and 5.3.3.
