How many cores does Code_Saturne use by default?
Mohammad
Post by Mohammad »
I'm using Code_Saturne 5.0 with the following system specs.
Architecture:        x86_64
CPU op-mode(s):      32-bit, 64-bit
Byte Order:          Little Endian
CPU(s):              8
On-line CPU(s) list: 0-7
Thread(s) per core:  2
Core(s) per socket:  4
Socket(s):           1
NUMA node(s):        1
Vendor ID:           GenuineIntel
CPU family:          6
Model:               60
Model name:          Intel(R) Core(TM) i7-4702MQ CPU @ 2.20GHz
Stepping:            3
CPU MHz:             2934.614
CPU max MHz:         3200.0000
CPU min MHz:         800.0000
BogoMIPS:            4389.69
Virtualization:      VT-x
L1d cache:           32K
L1i cache:           32K
L2 cache:            256K
L3 cache:            6144K
NUMA node0 CPU(s):   0-7
As you see, it has 8 cores.
But when running a case with Code_Saturne it says:
Does this mean it only uses one of the cores?
How can I force Code_Saturne to use maximum possible cores or threads?
Re: How many cores does Code_Saturne use by default?
You can select this in the GUI in the same page you are starting the simulation from.
Mohammad
Post by Mohammad »
Thanks. But I don't use GUI. Can you tell me how to do it without GUI? Thanks.
I recommend using the GUI. If you cannot use it for some reason, you will need to spend more time searching for information.
In any case, if you are using a supported batch system, the post-install step should help.
Otherwise, "code_saturne run --help" will provide the options.
Depending on your processor's memory bandwith, you might or might not get scalability to the full processor, so you need to run at least a few performance comparisons.
