CFD module on Salome
red_armyy
Post by red_armyy »
i want to know how to activate cfd module on Salome 8.3 , because when i type the command code_saturne salome , it shows this message : Salome is not available for this installation , i tried to type the command --with-salome="path of salome" , which was in a folder called "Salome-V8_3_0-univ-public" without success
, could you have a detailed explanation how to activate this module please ?
thanks
Re: CFD module on Salome
The command --with-salome="path of salome" must be used at the "configure" stage before compiling and installing the code so that the "code_saturne salome" option is available.
An altternative is to download a Salome_CFD binary package (check the Salome_CFD page here).
What type of install are you using ?
