Rough wall boundary conditions by cs_user_boundary_conditions.c
konst
Post by konst »
I am trying to impose boundary conditions by using c-functions, but not so many examples with that. So the question is:
How to set "z0" value for rough wall? I was trying to do it similarly to a fortran code:
  const int keyvar = cs_field_key_id("variable_id");
  //botom
  cs_selector_get_b_face_list("bottom", &nelts, lstelt);
  for (cs_lnum_t ilelt = 0; ilelt < nelts; ilelt++) {
    cs_lnum_t face_id = lstelt[ilelt];
    bc_type[face_id] = CS_ROUGHWALL;
    f = CS_F_(u);
    int ivar = cs_field_get_key_int(f, keyvar) - 1 + 0; // access to U_x
    icodcl[ivar * n_b_faces + face_id] = 6; //3??
    rcodcl[ivar * n_b_faces + face_id] = 0.001; //roughness value z0
but looks like it is a wrong way. It gives me error:
  (out of 1)
  has boundary condition type 6, center (0.25, 0, 0.25)
cs_boundary_conditions.c:363: Fatal error.
Thanks for helping.
(7.87 KiB) Downloaded 376 times
Re: Rough wall boundary conditions by cs_user_boundary_conditions.c
We really need to change the way we handle rough walls (using a separate field could be a good option, as it would also allow visualizing the roughness)...
In Fortran, the value for roughness for velocity is in rcodcl(ifac, iu, 3), that for scalars in rcodcl(ifac, iv, 3).
The equivalent in C would be:
  f = CS_F_(u);
  int ivarv = cs_field_get_key_int(f, keyvar) - 1; // access to U_x
  //bottom
    rcodcl[2*n_b_faces*nvar + ivarv*n_b_faces + face_id] = 0.001; //roughness value z0
Notice that I placed the access to f and computation of ivarv outside the loop (for better performance).
konst
Post by konst »
Thank you for reply, Yvan!
It is still not clear to me where is the value of "nvar" come from?
And I have the other question about rough wall. Maybe you can give some recommendations for first cell size in case of rough wall?
Konstantin
nvar is the number of independent (in the sense of having their own boundary conditions), and intervenes here because boundary condition values are saved in a non-interleaved mode (a relic from the old Fortran indexing chosen at the beginning of the project).
As regards the recommended cell size, I'll need to check with people who used the feature, but it would make sense for the cell size to be at least a few times larger than the roughness features.
konst
Post by konst »
Thanks for your reply, Yvan!
That approach works for me! )
Konstantin
