Source files for particle dispersion tutorial
Posted: Wed Sep 12, 2018 12:35 pm
by C.FLAG.
Dear Users, developers,
I am trying to perform the tutorial on particle dispersion in a turbulent pipe flow available here http://code-saturne.org/cms/sites/defau ... ticles.pdf. However, I am running version 5.0 of the code. Has anyone kept the file 'cs_user_particle_tracking.f90' corresponding to this tutorial and to the version 4.0 of the code? I would be happy to translate it to C and adapt it to version 5.0.
Cédric
Re: Source files for particle dispersion tutorial
Posted: Wed Sep 12, 2018 10:57 pm
Yes, this case is part of our documentation repository. The setup in 4.0 was not quite satisfactory, as the logic used could not function in parallel. I updated the case to 5.1, skipping 5.0, because the functionnality allowing a clean setup for this case was not available in 5.0.
I still had some issues in the injection, and Erwan has worked to fix and improve this tutorial recently. I did not check whether the update been pushed to the main documentation repo yet, so you should check with him.
