Dear Users, developers,
I am trying to perform the tutorial on particle dispersion in a turbulent pipe flow available here http://code-saturne.org/cms/sites/defau ... ticles.pdf. However, I am running version 5.0 of the code. Has anyone kept the file 'cs_user_particle_tracking.f90' corresponding to this tutorial and to the version 4.0 of the code? I would be happy to translate it to C and adapt it to version 5.0.
Cédric
Source files for particle dispersion tutorial
Re: Source files for particle dispersion tutorial
Yes, this case is part of our documentation repository. The setup in 4.0 was not quite satisfactory, as the logic used could not function in parallel. I updated the case to 5.1, skipping 5.0, because the functionnality allowing a clean setup for this case was not available in 5.0.
I still had some issues in the injection, and Erwan has worked to fix and improve this tutorial recently. I did not check whether the update been pushed to the main documentation repo yet, so you should check with him.
