Usage of user_physical_properties.c
senartcon
Post by senartcon »
Dear users,
I have entered my formulation for spatially varying density inside:
void
cs_user_physical_properties(const cs_mesh_t             *mesh,
                            const cs_mesh_quantities_t  *mesh_quantities)
Now how to return the output (density) to the corresponding property variable, as we do in the Fortran subroutine using propce(iel, ipcrom)? Could not find any example.
Thanks.
Re: Usage of user_physical_properties.c
Yes, we are still missing examples here, but examples for postprocessing may be helpful in showing how to access field values and properties.
In the case of pressure:
cs_real_t cvar_rho = CS_F_(rho)->val;
(adding "cs_field_pointer.h" to the includes section if missing)
or
cs_real_t cvar_rho = cs_field_b_name("density")->val;
Should provide access to the cell values array for density. The other examples (postprocessing/extra operations) may help you see how to access other variables you may need to determine density values.
senartcon
Post by senartcon »
thanks for your reply. In fact I found that all variable references can be found here:
https://www.code-saturne.org/cms/sites/ ... field.html
However, the variable density is not effected in the simulation., although this subroutine is compiled. I am using CS ver. 5.0.
My code is:
void
	cs_real_t *cvar_rho = CS_F_(rho)->val;
	for(cs_int_t cell_id=0; cell_id < mesh->n_cells; cell_id++)
		x = mesh_quantities->cell_cen[3*cell_id];
		y = mesh_quantities->cell_cen[3*cell_id+1];
		cvar_rho[cell_id] = f(x, y ...);
	return;
I don't remember the keyword to activate variable density (maybe irovar), but in the GUI, you can define the density as being variable (so that the field is defined), with a simple (constant) mathematical expression, the use your user function to set the actual values.
