configuration
attene
configuration
Post by attene »
Hello everybody,
I am about to configure my code saturne 5.0.8.
The configuration look like the following:
please find my questions between brackets.
$SALOME= /home/federico/salome/SALOME-8.4.0-CO6-SRC/BINARIES-CO6
$SOURCE=/home/federico/CS/code_saturne-5.0.8
$INSTALL_PATH=/home/federico/CS/CS_build
$SOURCE/configure --prefix=$INSTALL_PATH/with_salome_binaries \
--with-libxml2=$SALOME/libxml2 --with-hdf5=$SALOME/hdf5 \
--with-med=$SALOME/MED --with-cgns=$SALOME/cgns \
--with-metis=path_to_metis \
--with parmetis=/usr/local/bin/parmetis \ (This is the path for the executable (which parmetis), shall I call this in the configuration? or I should link the source folder? Do I have to do the same with all the packages?)
CC=icc CXX=icpc FC=ifort
ps: sorry for the basic questions but I do not have a lot of experience with linux and this kind of installation.
best regards,
FA
Re: configuration
Hellon
For the available options, run:
$SOURCE/configure --help
There is no separate METIS/PArMETIS option, so use "--with-metis=" for ParMETIS. And you do not want the executable, but the includes and libaries, so "/usr" should be enough if that is where it is installed (actually, since it is a default path, --with-metis should be enough).
The installation manual may provide some additional recommendations for specific libraries (such as Pt-Scotch, but if you are not using it, it is OK).
