lunching Code_Satrune without GUI
HBELG
Post by HBELG »
Hello everyone,
Is there a way to run a simulation on Code_Saturne, without passing throw GUI, with the geometry field and the .xml field?
Thanks for any help,
Re: lunching Code_Satrune without GUI
Yes, you can copy user_scripts.py from the DATA/REFERENCE to DATA directory of a case, and edit it.
You can then directly run the code using SCRIPTS/runcase or "code_saturne run".
I'll probably mive this thread to the general usage section.
HBELG
Post by HBELG »
Ok, thanks for replying
