Hi guys,
I wanted to ask you if it is possible and how can I select only the fluid volumes (cells) to impose a source term on them and exclude the boundary faces.
Thanks.
Costas
cs_user_source_terms
Re: cs_user_source_terms
I am not sure I understand what you want to do.
Source terms apply to volume cells, not boundary faces, so should not need any extra filtering of your volume criteria.
Thank you for your response. I was a bit confused with the cell_f_vol because basically I want to impose a uniform heat flux on the boundary walls and have the source term on the cells to balance out.
Costas
Costas
In addition to the last post, how can I calculate the mass flow rate for each cell?
Kind regards,
Costas
Kind regards,
Costas
As the mass flow on faces is available, summing it over a cell is possible. Check also the predefined functions in the user examples for "balance_by_zone" (which unfortunately se to have an incorrect link in the Doxygen documentation, which we need to fix)."
