Page 1 of 2
lift force calculation
Posted: Fri Apr 06, 2018 7:34 pm
by yany
I have used code_saturne over 1 year. But by now there is no meaningful result I have got.
I just ran a very simple aerofoil case. I used version 5.0.3.
The cs_user_extral_operation.f90 which is for lift and drag coefficient cannot link and compile. I don't know why. I attached the file and compile.log
In addition, I also used paraview to get the lift and drag. But the result is still not right. I used the formula "stress_Y*normal_Y" to get the lift force. Is that right?
I'm looking forward to your reply. Thank you very much.
all the best.
Re: lift force calculation
Posted: Sat Apr 07, 2018 9:01 pm
I c"an't tell which component of stress you need fo the lift force without knowing how your mesh is oriented.
For the user subroutine you can't use a subroutine written for version 4.0 in version 5.0, so you need to rewrite you code in the current version.
Posted: Sun Apr 08, 2018 6:25 pm
by yany
Thank you for the reply. I think that's the point.I used the subroutine for version in version 5.0. Is there any subroutines for version 5.0 could be used to calculate the lift and drag force?
I attached the mesh. The direction of free stream velocity is (1,0,0), so that that the direction of lift is (0,1, 0) I used "stress_Y*normal_Y" to get the lift force.
Thank you.
Yvan Fournier wrote:Hello,
Posted: Sun Apr 08, 2018 8:47 pm
Sorry, the version of the cs_user_extra_operations.f90 you attached is for version 4.0, not 5.0.
Posted: Wed Apr 11, 2018 4:59 pm
by Paul Brss
Hello Yany and Yvan,
I'm also working on lift and drag calculations over a NACA profile. I attached my cs_user_extral_operation.f90 subroutines. I changed some variables and the type of output files in order to make it readable by paraview easily. It's based on another cs_user_extral_operation.f90 subroutines found on this forum. I can try to find the topic if you want. Hope it can help !
So, I have good results for the lift, but not so good for the drag, according to the Sandia lab experimental results and Xfoil on NACA0015:
I use SST kw model, Re=1.0^6. My mesh is good, according to ICEM and respect the y+ condition at the wall. Does someone experience the same problem ?
I didn't find so much on SST kw on the CS documentations.
I can post my mesh and my case if you want (or create another topic on the forum if you prefer).
Posted: Thu Apr 12, 2018 4:08 pm
Did you try any other turbulence model ? Or other wall function options ? If your mesh is wall-resolved, I am not sure the default k-w is the best option.
Posted: Thu Apr 12, 2018 5:57 pm
by Paul Brss
Thanks for answering. Concerning the SST k-w, I tried the scalable two scales model (best one for my case), the 2 scales model and the 1 scales model. Is the functions "no wall function" still available ? I can't choose it.
I did not try any k-eps or Rij models cause I don't know them but I'll probably give it a try !
Posted: Fri Apr 13, 2018 4:43 pm
by Luciano Garelli
Here you can check the wall function options for the turbulence
https://www.code-saturne.org/cms/sites ... 9ec058107
Also I think that it is important to check the turbulent viscosity added by the turbulence method and the yplus.
Posted: Mon Apr 16, 2018 10:42 pm
by yany
Hello Paul,
Thanks soooooo much for your reply! I really appreciate that. You can try to use Paraview to calculate the drag force. I attached a link from youtube which may tell you how to do that.
https://www.youtube.com/watch?v=J944HOj_4b0
All the best, Yany.
Paul Brss wrote: Wed Apr 11, 2018 4:59 pm
Posted: Mon Apr 16, 2018 11:51 pm
by yany
Hello Paul,
But I have one more stupid question about your attached subroutine. It can get the value the lift and drag coefficient of "Foil", not the force?
All the best, Yan.
