calculation stopped without error profile output
yany
Post by yany »
Hello everyone,
I used the turbo-machinery module in code saturne on archer. I upload the setup-xml and mesh_output on archer. However the calculation always stopped without any error output. This problem confused me several months. Do you have any ideas about that??? Many thanks.
The listing :
command:
./cs_solver --mpi --param setup.xml
(R)
Code_Saturne
Version 5.0.4
Copyright (C) 1998-2017 EDF S.A., France
revision 5.0.4
build Thu Nov 16 18:20:53 2017
MPI version 3.1 (MPICH 3.2)
The Code_Saturne CFD tool is free software;
you can redistribute it and/or modify it under the terms
of the GNU General Public License as published by the
Free Software Foundation; either version 2 of the License,
or (at your option) any later version.
The Code_Saturne CFD tool is distributed in the hope that
it will be useful, but WITHOUT ANY WARRANTY; without even
the implied warranty of MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE. See the GNU General Public License
for more details.
Local case configuration:
Date: Tue Mar 20 10:55:18 2018
System: Linux 3.0.101-0.46.1_1.0502.8871-cray_ari_c
Machine: nid04776
Processor: model name : Intel(R) Xeon(R) CPU E5-2697 v2 @ 2.70GHz
Memory: 64523 MB
Directory: /fs3/e01/e01/yyan/rans/0018turbine/case1/RESU/20180319-2006
MPI ranks: 480 (appnum attribute: 0)
OpenMP threads: 1
Processors/node: 1
I/O read method: collective MPI-IO (explicit offsets)
I/O write method: collective MPI-IO (explicit offsets)
I/O rank step: 1
External libraries for partitioning:
ParMETIS 4.0.3
Reading metadata from file: "mesh_input"
CALCULATION PREPARATION
No error detected during the data verification
cs_user_parameters.f90 and others).
CALCULATION PARAMETERS SUMMARY
** DIMENSIONS
--- Physics
NVAR = 11 (Nb variables )
NSCAL = 0 (Nb scalars )
NSCAUS = 0 (Nb user scalars )
NSCAPP = 0 (Nb specific physics scalars )
** VOF METHOD
IVOFMT = -1 ( -1: inactive )
( 0: active )
** HOMOGENEOUS MIXTURE MODEL FOR CAVITATION
ICAVIT = -1 (-1: single phase flow )
( 0: no vap./cond. model )
( 1: Merkle's model )
** TIME STEPPING
--- Per-variable properties
Variable ISTAT CDTVAR
Velocity 1 0.1000E+01
Pressure 0 0.1000E+01
r11 1 0.1000E+01
r22 1 0.1000E+01
r33 1 0.1000E+01
r12 1 0.1000E+01
r23 1 0.1000E+01
r13 1 0.1000E+01
epsilon 1 0.1000E+01
ISTAT = 0 ou 1 (1 for unsteady )
CDTVAR > 0 (time step multiplier )
--- Order of base time stepping scheme
ISCHTP = 1 (1: order 1; 2: order 2 )
** STOKES
-- Phase continue :
ISTMPF = 1 (time scheme for flow
(0: explicit (THETFL = 0 )
(1: std scheme (Saturne 1.0 )
(2: 2nd-order (THETFL = 0.5 )
THETFL = -0.99900E+03 (theta for mass flow )
IROEXT = 0 (density extrapolation
(0: explicit
(1: n+thetro with thetro=1/2
(2: n+thetro with thetro=1
THETRO = 0.00000E+00 (theta for density
((1+theta).new-theta.old
IVIEXT = 0 (total viscosity extrapolation
(0: explicit
(1: n+thetvi with thetro=1/2
(2: n+thetvi with thetro=1
THETVI = 0.00000E+00 (theta for total viscosity
ICPEXT = 0 (specific heat extrapolation
(0: explicit
(1: n+thetcp with thetro=1/2
(2: n+thetcp with thetro=1
THETCP = 0.00000E+00 (specific heat theta-scheme
THETSN = 0.00000E+00 (Nav-Stokes S.T. theta scheme)
THETST = 0.00000E+00 (Turbulence S.T. theta-scheme)
EPSUP = 0.10000E-04 (Velocity/pressure coupling
stop test )
** BASE ITERATIVE SOLVERS
Variable EPSILO IDIRCL
Velocity 0.1000E-07 1
Pressure 0.1000E-07 1
r11 0.1000E-07 1
r22 0.1000E-07 1
r33 0.1000E-07 1
r12 0.1000E-07 1
r23 0.1000E-07 1
r13 0.1000E-07 1
epsilon 0.1000E-07 1
EPSILO = (resolution precision)
IDIRCL = 0 ou 1 (shift diagonal if
ISTAT=0 and no Dirichlet)
** CALCULATION MANAGEMENT
--- Restarted calculation
ISUITE = 1 (1: restarted calculation )
ILEAUX = 0 (1: read restart/auxiliary )
IECAUX = 1 (1: write checkpoint/auxiliary)
--- Calculation time
The numbering of time steps and the measure of simulated
physical time are absolute values, and not values
relative to the current calculation.
INPDT0 = 0 (1: 0 time step calcuation )
NTMABS = 500 (Final time step required )
--- CPU time margin
TMARUS = -0.10000E+01 (CPU time margin before stop )
** INPUT-OUTPUT
--- Restart file
NTSUIT = 100 (Checkpoint frequency )
--- Probe history files
NTHIST = 1 (Output frequency )
FRHIST = -.10000E+01 (Output frequency (s) )
--- Log files
NTLIST = 500 (Output frequency )
Number Name IWARNI verbosity level
(-999: not applicable)
Velocity 0
Pressure 0
r11 0
r22 0
r33 0
r12 0
r23 0
r13 0
epsilon 0
TurbVisc -999
CourantNb -999
FourierNb -999
total_pressure -999
Yplus -999
--- Additional post-processing variables (ipstdv)
ipstfo = 1 (Force exerted by the
fluid on the boundary)
ipstyp = 1 (y+ at boundary)
ipsttp = 0 (T+ at boundary)
ipstft = 1 (Thermal flux at boundary)
ipstnu = 0 (Dimensionless thermal
flux at boundary)
** ALE METHOD (MOVING MESH)
IALE = 0 (1: activated )
NALINF = 0 (Fluid initialization
iterations)
IFLXMW = 0 (ALE mass flux computation
0: thanks to vertices
1: thanks to mesh velocity)
Postprocessing output writers:
-1: name: results
directory: postprocessing
format: EnSight Gold
options:
time dependency: transient connectivity
output: every 20 time steps and at calculation end
-5: name:
directory: monitoring
format: time_plot
options:
time dependency: fixed mesh
output: every 1 time steps
-6: name:
directory: profiles
format: plot
options:
output: at calculation end
Reading file: mesh_input
Finished reading: mesh_input
No "partition_input/domain_number_480" file available;
Partitioning by space-filling curve: Morton (in bounding box).
Number of cells per domain (histogramm):
[ 21207 ; 21208 ] = 480
Partitioning finished (30.9 s)
Joining number 1:
Selection criteria: "not (INTERFACE or INTERFACE2)"
Parameters for the joining operation:
Shortest incident edge fraction: 0.10000
Maximum angle between joined face planes: 25.00000
Advanced joining parameters:
Verbosity level: 1
Visualization level: 1
Deepest level reachable in tree building: 30
Max boxes by leaf: 25
Max ratio of linked boxes / init. boxes: 5.00000
Max ratio of boxes for distribution: 2.00000
Merge step tolerance multiplier: 1.00000
Pre-merge factor: 0.05000
Tolerance computation mode: 1
Intersection computation mode: 1
Max. number of equiv. breaks: 500
Max. number of subfaces by face: 200
Before joining
Number of cells: 10179720
Number of interior faces: 0
Number of boundary faces: 61078320
Number of vertices: 81437760
Global number of boundary faces selected for joining: 60668748
Element selection successfully done.
Global min/max. tolerance:
Glob. Num. | Tolerance | Coordinates
22 | 0.000002 | 1.2344007860e-01 8.4999084160e-01 -6.0000000000e-01 | ORI
9506 | 0.002833 | 6.7919450960e-03 1.2067073530e+01 4.8166666670e-01 | ORI
Determination of possible face intersections:
bounding-box tree layout: 3D
Re: calculation stopped without error profile output
Do you have any output in the batch log file ? any error_* files ?
It seems the computation got "stuck" in a given stage and did not progress, so you would expect a "time up" type message in the batch log.
Attaching a debugger here would help pinpoint where the computation is "stuck". On some systems, we have issues with "MPI_Alltoallv" operations hanging when too many nodes are exchanging data. This should not happen, but is MPI library-related, so settings on the MPI side may help.
I am not sure whether you are using vanilla MPICH or Intel-MPI (the "listing" does not really tell). With Intel MPI, some environment variables may help, especially I_MPI_ADJUST_ALLTOALLV.
yany
Post by yany »
There is a error file output, but it's blank. And there is file end with .o5190971 output as followed,
yyan Job: 5190879.sdb started: 20/03/18 10:29:56 host: mom3 ***
*** yyan Job: 5190879.sdb started: 20/03/18 10:29:56 host: mom3 ***
ModuleCmd_Switch.c(179):ERROR:152: Module 'PrgEnv-cray' is currently not loaded
/home3/e01/e01/yyan
Currently Loaded Modulefiles:
1) modules/3.2.10.6
2) nodestat/2.2-1.0502.60539.1.31.ari
3) sdb/1.1-1.0502.63652.4.25.ari
4) alps/5.2.5-2.0502.9955.44.1.ari
5) lustre-cray_ari_s/2.5_3.0.101_0.46.1_1.0502.8871.22.1-1.0502.21658.55.1
6) udreg/2.3.2-1.0502.10518.2.17.ari
7) ugni/6.0-1.0502.10863.8.29.ari
8) gni-headers/4.0-1.0502.10859.7.8.ari
9) dmapp/7.0.1-1.0502.11080.8.76.ari
10) xpmem/0.1-2.0502.64982.5.3.ari
11) hss-llm/7.2.0
12) Base-opts/1.0.2-1.0502.60680.2.4.ari
13) intel/17.0.0.098
14) craype-network-aries
15) craype-ivybridge
16) craype/2.5.10
17) pbs/12.2.401.141761
18) cray-mpich/7.5.5
19) packages-archer
20) xalt/0.6.0
21) cse-compute-defaults/3.0
22) cray-libsci/16.11.1
23) pmi/5.0.13
24) atp/2.1.0
25) PrgEnv-intel/5.2.82
/work/e01/e01/yyan/rans/0018turbine/case1/RESU/20180319-2006
[NID 00046] 2018-03-20 10:39:12 Apid 30319988: initiated application termination
[NID 00045] 2018-03-20 10:39:14 Apid 30319988: OOM killer terminated this process.
[NID 00046] 2018-03-20 10:39:14 Apid 30319988: OOM killer terminated this process.
[NID 00044] 2018-03-20 10:39:14 Apid 30319988: OOM killer terminated this process.
[NID 00043] 2018-03-20 10:39:14 Apid 30319988: OOM killer terminated this process.
Application 30319988 exit signals: Killed
Application 30319988 resources: utime ~0s, stime ~8s, Rss ~7296, inblocks ~199448, outblocks ~469584
Resources requested: ncpus=192,place=free,walltime=00:20:00
Resources allocated: cpupercent=0,cput=00:00:02,mem=8668kb,ncpus=192,vmem=172772kb,walltime=00:09:21
*** yyan Job: 5190879.sdb ended: 20/03/18 10:39:17 queue: S5184105 ***
Yvan Fournier wrote:Hello,
yany
Post by yany »
Hi, Yvan,
The output summery file is attached. Could you help me to have a look at it ? Is there anything wrong could be present in this file? Thank you.
All the best, Yan.
summary.doc
(32.71 KiB) Downloaded 587 times
No, it seems even the summary was not updated (which is expected in the case the job is stopped by the batch system/resource manager).
How about the files I recommended (the batch output log, probably in the directory the case was submitted from) ?
