Hello everyone,
I am running a simulation of a pump in a complex geometry in Code Saturne 5.0. I try to compute a steady state with the frozen rotor Turbomachinery module.
The clipping section of equation parameters in the numerical parameters only permits clipping of temperature and user defined variable, is there a way to access clipping for the other variables such as pressure and velocity?
Thank you very much!
How to enable clipping of pressure and velocity in CS 5
Re: How to enable clipping of pressure and velocity in CS 5
I'm not sure about velocity, but you can't clip pressure, which has a specific role in incompressible flow resolution algorithms.
In the commercial software such as FLUENT, they automatically re-set the "too large" values of the velocity and turbulence scalars like k or epsilon, when the mesh quality is not as high as we wish, to facilitate the convergence of the solution.
Is that possible to do the clipping for k-epsilon and velocity in CS 5.0.8? And how? In which routine?
Kind regards
Zhenaln
Kind regards
Zhenaln
Yvan Fournier wrote:Hello,
k and epsilon are clipped automatically, based on allowed ranges (but occurrence of clipping is a sign of "not-so-well behaved" case. Velocity and pressure can not be clipped cleanly, as that basically changes the velocity-pressure coupling.
You can always try changing the velocity between 2 time steps in cs_user_extra_operations, but this is not definitely not recommended...
