Hi!
I have one question.
Is possible to change de BC on a running test? I want to say, outlet to wall? or any other BC
that is for I need to simulate the close of a valve.
Change boundary condition on running
Luciano Garelli
Re: Change boundary condition on running
I'm really not sure that you can change a BC type during runtime, but may be a workaround to this problem is to set a time varying porosity or head loss on the cells that represent the valve.
Also, you can check these posts, maybe can help you.
viewtopic.php?f=2&t=2047
viewtopic.php?f=2&t=1968
Hi!
Thanks for you answer Luciano.
I already change my boundary condition outlet --> wall or any other BC. not only that, I too changed in the same group, BC for each face.
I used subroutine cs_user_boundary_condition.f90, physics time (ttcabs), geometrical variables, and conditions.
I try too using porosity condition to comparation of result.
Thanks!
Thanks!
