Electric arcs test case using Code Saturne 5.0.4
will214
Post by will214 »
Hello everyone. I am a new user of Code_Saturne. I want to simulate electric arc by this software. Could anyone provide a test case of electric arcs using Code Saturne 5.0.4. In the forum, there is test case using Code Saturne 4.0, but when I run the code, there is an error, so is there a test case under Code Saturne 5.0.4. Thank you very much!
Re: Electric arcs test case using Code Saturne 5.0.4
Here is an updated setup.
PFENDER_v5.0.tar.gz
(991.72 KiB) Downloaded 257 times
will214
Post by will214 »
Thank you very much! I will check it.
