Hello I'm trying to install version 5.0.4 on Mac (high Sierra).
During configuration I get the following error: "configure: error: cannot find PyQt5 support (>= 5.0) or PyQt4 support (>= 4.5), Graphical User Interface cannot be installed"
Please note that:
- both Pyqt4 and pyqt5 are correctly installed
- i have tried specifying "./configure PYUIC4=/usr/local/Cellar/pyqt@4/4.12.1/bin/pyuic4 PYRCC4=/usr/local/Cellar/pyqt@4/4.12.1/bin/pyrcc4" but the error is still present
- i have tried specifying --with-python_exec=/usr/bin
- I have tried reinstalling python, qt and pyqt
Any help will be highly appreciated.
CS
PYQT issue
PYQT issue
- config.log
- (221.39 KiB) Downloaded 841 times
Re: PYQT issue
should not be supported anymore, but
PYTHON=/usr/bin/python
should work.
Could you try in a terminal:
and post the output ? OR do the same with PyQt4 ? This is the basic test used in the code for PyQt support, so should allow logging errors.
should work.
import sys, string
try: import PyQt5
except ImportError: sys.exit(1)
from PyQt5.QtCore import *
if list(map(int, QT_VERSION_STR.split('.'))) < [5,0,0]: sys.exit(1)
if list(map(int, PYQT_VERSION_STR.split('.'))) < [5,0,0]: sys.exit(1)
sys.exit(0)]"Regards,
Re: PYQT issue
First of all, thanks for you answer.
-setting python path didn't work
-qt4 output is attached
regards
CS
regards
CS
- Output1.txt
- (5.39 KiB) Downloaded 871 times
Re: PYQT issue
Also, PYTHON=/usr/local/bin/python3 seems to be producing a fine output. I'll try and let you know asap.
Re: PYQT issue
I forgot to mention in my previous post that the commands I listed should be typed in a Python shell... Could you try that ?
It is possible as that you installed PyQt only for Python. In this case, forcing PYTHON=..
to use python3 should work.
