Error of using standard modules during compilation
rodion
Post by rodion »
Hello everyone,
I work on the simulation of electric arc in DC plasma torch with electrodes included into the domain. Before I have used Code_Saturne 4.2 and recently I've decided to switch to Code_Saturne 5.0 because I need internal coupling for electrodes simulation.
I compared user code examples for CS5.0 with my code files for CS4.2 and adapted my code files for CS5.0. But if I start compilation, I encounter 27 similar problems as following:
 use numvar
    1
Error: ‘cs_user_initialization’ of module ‘numvar’, imported at (1), is also the name of the current program unit
/home/rodion/TransfArc/Case3_Argon/RESU/20170731-2002/src_saturne/cs_user_initialization.f90:89:4:
 use optcal
    1
Error: ‘cs_user_initialization’ of module ‘optcal’, imported at (1), is also the name of the current program unit
/home/rodion/TransfArc/Case3_Argon/RESU/20170731-2002/src_saturne/cs_user_initialization.f90:90:4:
 use cstphy
    1
Error: ‘cs_user_initialization’ of module ‘cstphy’, imported at (1), is also the name of the current program unit
/home/rodion/TransfArc/Case3_Argon/RESU/20170731-2002/src_saturne/cs_user_initialization.f90:92:4:
Please find compilation log attached.
I encounter this problem on Ubuntu with CS5.0 and on Windows with CS4.3.
Does somebody know how can I compile my code with using standard modules and start calculation with CS5.0?
Rodion
compile.log
(28.3 KiB) Downloaded 282 times
Re: Error of using standard modules during compilation
Could you also post your user subroutines ?
rodion
Post by rodion »
Thank you for your answer, Yvan.
Please, find the files attached.
Rodion
(8.67 KiB) Downloaded 287 times
cs_user_parameters.f90
(41.98 KiB) Downloaded 283 times
cs_user_boundary_conditions.f90
(29.37 KiB) Downloaded 280 times
rodion
Post by rodion »
Please, find three files more attached.
Rodion
usthht.f90
(12.99 KiB) Downloaded 292 times
cs_user_source_terms.f90
(39.7 KiB) Downloaded 285 times
cs_user_physical_properties.f90
(16.77 KiB) Downloaded 284 times
The profile of some subroutines has changed betwwen versions. Your update was not correct.
I attached some updated versions which compile now.
When updating, it is always safer to compare user functions with the ones in REFERENCE (using tools such as meld, or your favorite file comparison tool).
(44.08 KiB) Downloaded 302 times
(8.81 KiB) Downloaded 244 times
rodion
Post by rodion »
The compilation is okay now. Thank you very much!
But the file cs_user_initialization.f90 is not active.
I can see its mentions in the compile.log (please find it attached), but it doesn't make initialization of enthalpy and doesn't output anything to the console or listing.
I have checked the same file in C (cs_user_initialization.c), it works.
Do you know what can be the reason of this problem with initialization in Fortran?
Rodion
compile.log
(25.97 KiB) Downloaded 262 times
Are you using a packaged version of Code_Saturne on Ubuntu ? If this is the case, there is a known bug, referenced on this forum and submitter on the Ubuntu bug tracker (with no progress), realted to this. If not, what system/install method are you using ?
rodion
Post by rodion »
I have tried CS5.0 on Windows 7 and Ubuntu 16. Initialization in Fortran doesn't work on both OS.
By the way, I have just found that cs_user_physical_properties.f90 doesn't work too, while the compilation is okay.
How can I make it work?
Rodion
Could you post your setup, as per the forum usage recommandations ?
rodion
Post by rodion »
Please find the files attached.
The mesh is too big for the message, so please find it by the following link:
https://drive.google.com/open?id=0BzeG5 ... UpqclFBSmM
Rodion
setup.xml
(7.54 KiB) Downloaded 234 times
performance.log
(24.36 KiB) Downloaded 271 times
preprocessor.log
(8.69 KiB) Downloaded 286 times
