Problem : Add scalars without GUI Code-Saturne version 4.3
HTNguyen
Post by HTNguyen »
I'm a newbie of code_saturne version 4. I now want to add scalars without using GUI. I defined a scalar in cs_user_ parameters.c as below:
void
cs_user_model(void)
  /* If the GUI is used, user fields should preferably be defined with the GUI,
     so that associated numerical options, boundary conditions, initializations,
     and such may also be defined using the GUI. */
  if (cs_gui_file_is_loaded())
    return;
    cs_parameters_add_variable("tracer", 1);
and I got an error
** SOLVING VARIABLE tracer
 _iterative_vector_gradient: isweep = 2, normed residual: 3.069990e-13, norm: 3.645661e+04, var: velocity
cs_field.c:989: Fatal error.
Fortran pointer of rank 1 requested for values of field "velocity",
which have rank 2.
   1: 0x7f49cb4a05b8 <cs_f_field_var_ptr_by_id+0x88>  (libsaturne.so.0)
   2: 0x7f49cba475b5 <__field_MOD_field_get_val_prev_s+0x21> (libsaturne.so.0)
   3: 0x7f49cb7b56c4 <divrit_+0x7fd>                  (libsaturne.so.0)
   4: 0x7f49cb46e4f0 <covofi_+0x3ab6>                 (libsaturne.so.0)
   5: 0x7f49cb571d9a <scalai_+0xb68>                  (libsaturne.so.0)
   6: 0x7f49cb57db9f <tridim_+0x5dff>                 (libsaturne.so.0)
   7: 0x7f49cb445854 <caltri_+0x27a4>                 (libsaturne.so.0)
   8: 0x7f49cb428d7a <cs_run+0x48a>                   (libsaturne.so.0)
   9: 0x7f49cb4287a5 <main+0x125>                     (libsaturne.so.0)
  10: 0x7f49caac7830 <__libc_start_main+0xf0>         (libc.so.6)
  11: 0x4047b9     <_start+0x29>                    (cs_solver)
Does anyone have the solution?
Thanks in advance.
Re: Problem : Add scalars without GUI Code-Saturne version 4
The info is not sufficient to guess at the problem. Please follow the recommendations in the forum usage guidelines to see what to provide.
Also, v4.3 is obsolete and not maintained any more, so switching to v5.0 is recommended.
