Version 5.0 on Windows
xingjian
Post by xingjian »
I have just installed version 5, it has two new fonctions, I would like to know whether the automatic scheme is better than the first order scheme, and if I use iterative process error estimators (with / without volume contribution), can i get a better convergence result?
When I start to calculate it, it can not run, it shows:
'code_saturne' n'est pas reconnu en tant que commande interne
That is:
'Code_saturne' is not recognized as an internal command
How can i solve it?
By the way, it matches which version of med? Is this a problem with med version does not match? I used MED 3.0 files.
Thank you very much
Best Regards
XING Jian
Re: Version 5.0 on Windows
You did not tell me whether you have another install or not. Also, did you run from the GUI or try running directly SCRIPTS/runcase.bat ? If you did not try it, can you try ?
The MED version is 3.2, so it should be able to read MED 3.0 files.
xingjian
Post by xingjian »
I am sorry about that, I have uninstalled version 4 when I installed version 5.
I run it from GUI, I am sorry that I don't know how to run it from SCRIPTS/runcase.bat. How to do it? Please teach me...
Thank you very much
Best Regards
XING Jian
Just run t from a terminal (command line) or even double-click on the file from the file manager.
xingjian
Post by xingjian »
I am sorry I don't know how to run it from a terminal, but I tried double-click on the file runcase in the file of SCRIPTS, only one black window flashed,then nothing happened.
Thank you very much
Best Regards
XING Jian
Could you post the runcase.bat file ?
xingjian
Post by xingjian »
I am so sorry, It's my problem, you just reminded me, I was just aware of this problem and I was using the runcase of version 4.0.6, I forgot to create a new case with version 5. Now it's no problem.
Thank you very much
Best Regards
XING Jian
OK, that's good news.
AlexKaz
Post by AlexKaz »
Hi!
GUI of a previous version for Linux has a button "Check mesh". I though there is such button at Windows GUI, but v5 hasn't. I can not make right boundary conditions then. I've try to use Salome-Meca v7.2.0 with mesh format MED v3.0 and v8.2.0 with MED v3.2. Has a work process with GUI changed recently or have I messed something in GUI? Thanks.
Added.
I'm sorry, I have solved my problem=) Now the solution goes well.
