2D_AIRFOIL TESTCASE
aladdincham
2D_AIRFOIL TESTCASE
Post by aladdincham »
Hi all,
I want to do a simulation about 2D airfoil, but I have tried so many times but I got a failure. Can somebody help me?
In addition, can someone tell me how to calc the lift, drag and moment coefficients?
Thanks very much!
2d_airfoil.zip
test file
(7.75 MiB) Downloaded 567 times
Luciano Garelli
Re: 2D_AIRFOIL TESTCASE
Post by Luciano Garelli »
I think that you forget to specify the velocity direction at inlet BC, maybe this is the problem.
Always search in the forum your keywords ("lift, drag, etc") in order to know if someone has ask the same question, I leave here a link
http://code-saturne.org/forum/viewtopi ... =2&t=2059
Also, you can check the file cs_user_extra_operations-global_efforts.f90 at SRC/EXAMPLE directory
