Can't impose velocity profile in Code Saturne
Jundi He
Post by Jundi He »
Hi:
In Code Saturne, I use constant velocity in the inlet surface, and the case can run, but when I use the user law and write my own velocity profile, it failed, said that:
This is my setting of the inlet velocity profile, I think there is nothing wrong with the equation. Anyone knows what's wrong? Thank you!
Best Regards!
Jundi He
Re: Can't impose velocity profile in Code Saturne
I tested your expression under Python, and it seems you start having negative numbers when the radius goes from 0.01 to 0.02.
I'll let you double check.
Jundi He
Post by Jundi He »
Hi:
Many thanks, I need to use the "abs" to make sure that it is positive value.
Best Regards!
Jundi He
