Porosity:Unable to get desired pressure drop
Posted: Wed Sep 28, 2016 12:51 pm
I am solving for head loss from porous region in a square duct using code saturne 4.2. Square duct is of length 10m with cross section of 0.5m * 0.5m i.e. 0.5*0.5*10 (X*Y*Z). It has porous region of length 1 m at middle i.e. from Z=4.5m to Z=5.5m.Pressure drop is obtained from equation given in code saturne user manual, i.e.-
rho*du/dt=-0.5*rho*alpha*|u|u
Where rho is density
u is velocity
Alpha is loss coefficient (per meter)
For steady flow simulation I have used following properties:
Density =1.225 kg/m^3
Viscosity = 1.7894 Pa.s
Reference pressure = 101325 Pa
Turbulence model = k-epsilon scalable two scales model
Head loss coefficient,Alpha=103.082
Inlet velocity=8 m/s
Turbulence - Calculation by turbulence intensity
Intensity=5%
Hydraulic Diameter=0.5 m
Gradient calculation method - Least square method over extended neighbourhood
Velocity-pressure coupling-SIMPLE
No. of iteration=500
Using formula for head loss as stated above I should get pressure drop of 4040.8144 Pa across porous region. But I am getting 2223.17 Pa pressure drop as measured at Points at start (Z=4.5m) and end (Z=5.5m) of porous zone.
Please tell me why I am unable to get desired pressure drop?
.xml File and pictures of mesh are attached below
u is velocity
Intensity=5%
